Passenger window problem
Old Jun 24, 2013 | 10:14 AM
shuggy81's Avatar
Default Passenger window problem
Hi Guys,
I have read that the A4's are notorious for the regulator failure. However I wanted to make sure it is this that's causing my particular issue.
My baby has done 90k, 1.8t Q. Issue is that the from the drivers side, I am able to roll the drivers side up/down no problem. When it comes to passenger, it goes down fine however now doesn't roll up. Before I had to press the button a few times for it to eventually work. However if i control the window from the passengers side it works completely fine from there.
Still the drivers side regulator you think ?
Thanks
Old Jun 24, 2013 | 09:09 PM
JDJ's Avatar
JDJ
If the passenger window works fine from the passenger side switch, I would guess the problem is either the switch on the driver's side or the wiring of the driver's side switch.
rkelsey10554
Feb 3, 2014 10:03 PM
damich123
Sep 29, 2011 11:56 AM
Turbo123
Aug 27, 2010 04:07 PM
T Man 96
Feb 21, 2010 07:27 PM
baxterboxer
Jul 6, 2006 12:03 PM
