00 4.2 Passenger Window Problem?
Old Jun 9, 2006 | 11:44 AM
baxterboxer's Avatar
Default 00 4.2 Passenger Window Problem?
Just bought a 00 4.2 for a good deal, but i am starting to have issues with the passenger window. Intermittently, (more often than not!), the window will go up, slow down, stop, and then go straight down. it doesn't seem to be blocked by anything. can this be the switch? is the window off the track? is the window motor the problem? has any anyone else had this problem? i don't think it is the switch as this will occur from the driver master window controller and the passenger door window switch. before i go nuts figuring this out, i am hoping someone may of had a similar problem with possible solution.
also, since i am unfamiliar with audis, once going, the car runs loudly - almost like a quite bearing issue. is this "growl" common with these cars due to the all wheel drive?
thanks - any help you can give is greatly appreciated!
Old Jun 9, 2006 | 12:25 PM
slee22's Avatar
Default RE: 00 4.2 Passenger Window Problem?
A window guide is broken (quite common). You can get one from HERE And install instructions are HERE
Old Jun 9, 2006 | 12:26 PM
Boston Driver's Avatar
You most likely have an issue with the plastic window guide, which is known to fail. There is a DIY writeup on how to repair this problem here: AudiWorld Tech Article: replacing window guide clips
I think eveerything you need is listed here, and I think Audi actually upgraded the replacement part, so don't be suprised if it is another color (like pink or light orange?).
As far as the loudness of your car, maybe something with the exhaust? Did the prior owner do anything to the exhaust? I installed the OEM RS6 sound enhanced exhaust on my 2002 A6 4.2, and WOW does this thing GROWL!!!
Old Jul 6, 2006 | 12:03 PM
guys, can't thank you enough. the window guides were the problem. relatively inexpensive to fix as well. took it to my local mechanic with the directions you forwarded. thanks again for the help!
rkelsey10554
Feb 3, 2014 10:03 PM
shuggy81
Jun 24, 2013 09:09 PM
damich123
Sep 29, 2011 11:56 AM
Turbo123
Aug 27, 2010 04:07 PM
T Man 96
Feb 21, 2010 07:27 PM
