Please check out my Vag Logs - boost issues
Old Apr 21, 2010 | 09:26 AM
Rn3037's Avatar
Default Please check out my Vag Logs - boost issues
My issue is that there is a ton of lag and the car is sluggish, the boost "skips" up a few psi then goes to 18 then goes down to 10 then up to 15... I also don't hear my turbo like I used to, I hear more of an air sound from the intake, I don't hear the high pitched whistle.
Tests I did:
Pressure tested, didn't find leaks, adjusted wastegate actuator to open at ~10psi, tried the stock DV and a Forge...
Mods: GT2X (oil/water cooled) - N249 bypass - Hyperboost DV - VMR test pipe - Speedtuning tune - 415cc genesis injectors
Here are 2 logs - Let me know what you think the issue might be:
http://foundationsupplements.com/GT2X LOG.csv
http://www.foundationsupplements.com...%2020%2010.CSV
NOTE: running a little lean b/c I put the stock injectors back in to see if that was the issue, but it wasn't
TurboFick
Dec 26, 2012 05:44 PM
gotaudi
Dec 5, 2007 02:42 PM
pfeifstudd
Sep 16, 2007 09:35 PM
TeeterTawter
Jul 29, 2007 12:13 AM
onepoint8tee
Jun 27, 2007 04:38 PM
