power windows not working
Old Feb 16, 2013 | 04:25 PM
Valentin's Avatar
anyone any new suggestions?
I changed the switches,
I did not find any wire interrupted.
in VCDs measuring blocks i can see each swich in what position is.
I think the way comfort is ok(everything works fine, except for windows), but is blocked since I made ​​a diagnosis with vag-com.
I came down the window to smoke and made a diagnosis, but when I leave the car I could not lift the window.
what could happen?
my CCM is codding like :
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AT
Component: Komfortgerát T23 1412
Coding: 06720
Shop #: WSC 06335
VCID: 830F11D5910EB91
thanks
Old Jul 31, 2013 | 06:52 AM
majzelj's Avatar
Hi!
Do you solve your problem.
I have the same problem about power windows, that you had it.
Thanks!
Old Jul 31, 2013 | 11:14 PM
Gman 56's Avatar
maybe because you was using the vag com to diagnose a problem you rolled down the window that might have caused the problem.I know it sounds crazy but it worked before the vag com was hooked up.maybe caused a comp glitch?
Old Aug 1, 2013 | 07:56 AM
majzelj's Avatar
I figure-out what was the problem on my car.
The central module for comfort electronic fail, I changed it and windows work again.
Does anybody know , how can I reprogram the old module, my opinion is only software problem on the module.
Old Jan 31, 2015 | 06:28 PM
robert palmer's Avatar
Default allroad quattro
have a 2003 allroad and today the electric windows and locking system quit key fob wont lock it none of the window switches will work the only fuse I can find is a locking system 5 amp witch looks ok Iam lost
Old Jun 5, 2015 | 05:24 AM
Smithypj's Avatar
Default Windows and key fob stopped working
Help!!!
Same has happened to me today, did you solve the problem?
Steph
Old Jul 16, 2015 | 11:23 PM
timmyk's Avatar
Default Double check the doorwire harness
The door wires get brittle and broken down. This happened to my 2002 A4 Avant Quattro. You can buy a used harness for 40-60 dollars online.
Old Dec 18, 2016 | 02:50 AM
  #18
Fanel307's Avatar
what could happen?
Coding: 06720
Shop #: WSC 06335
thanks
Hi,
Did you find the issue ?
I am in the same situation.
Before the windows completly stopped working it happend around 4 times to either not open or not getting it up , they started working after around 30 min of driving.
When they stopped working for good , I left my home , after 10 min I tried to open , no response , after another 20 min they worked fine while running the car wheels . When I stopped for parking to get the entrance ticket i pressed down the button, the window responded but after that it did not come up anymore. From that point after getting home i manually got it up but could not get down anymore so all windows blocked up now.
I scanned it with vcds, everything is clean, no errors.
I checked fuses, continuouity of wires, main controls on the doors are lighten but none is operating.
I woul appreciate any guidance.
Thank you
Le. It is an audi a4 b7 1.9 tdi 09/2006
Old Mar 20, 2017 | 04:45 PM
  #19
CavalierLion1's Avatar
Did you find the problem?
I have the same problem.
Old Mar 21, 2017 | 10:36 AM
  #20
Valentin's Avatar
Hello
my problem was a power wire on comfort module under the driver seat.
I used a multimeter and I saw that there is tension on it. I powered from the another wire and everything returned to normal.
I would not be able to say exactly where. much time has passed since then.
I think to me it was something solder joint or something jumped because of potholes.
try to get diagrams and see if you have electricity on correct wire.
have a nice day
