prep-painted-baked!
Old May 15, 2013 | 12:22 AM
tofast2belast's Avatar
Default prep-painted-baked!
so i started out replacing the coolant flange AGAIN on the back of the engine block due to leak and also replacing thermostat housing so i was like might as well do this while its apart
Attached Thumbnails prep-painted-baked!-168199_10100164391739790_2067343517_n.jpg   prep-painted-baked!-260217_10100164391754760_1972305233_n.jpg   prep-painted-baked!-936307_10100164391784700_1811777436_n.jpg   prep-painted-baked!-945425_10100164391804660_937639884_n.jpg
Old May 15, 2013 | 06:25 PM
pa4ul's Avatar
so shiny! ooooooolala!
Old May 16, 2013 | 06:19 AM
yea man i liked how it turned out. i did the valve cover first last week and it looked almost too shiny you know like that fake chrome crap. well when i was taking the injectors out gas got on the valve cover and started stripping it. so when i did the intake i found clear coat that can be baked on to make it chemically resistant, and also turned that too shiny thing to a darker metal look.
Old May 16, 2013 | 04:57 PM
pa4ul's Avatar
looks good take a pic of the valve cover! Ive wanted to do that for so long but never made a point to! Maybe this is just the inspiration i need.
Old May 17, 2013 | 06:19 AM
i just did the valve cover again yesterday, ill take a pic tonight when i get back to my garage.. just got to connect the SAI pump back up, put injectors in, connect TP hose and fill with coolant today
Old May 19, 2013 | 08:45 AM
update: car back together. coolant gauge still fluctuates like before(coolant gauge needle would move back and forth a little once warmed up), i have changed the thermostat housing and the coolant flange on the back of the engine. so i am not sure if its because there is still air in the system?
here is pics of engine bay with valve cover painted too.
i painted the valve cover the same color as IM and TB but it got a greenish tint to it, kinda like the color, probably happened because of heat and curing process..
Attached Thumbnails prep-painted-baked!-photo-2.jpg   prep-painted-baked!-photo-4.jpg
OTD
Jan 3, 2013 02:46 AM
shao1inki11ab33
Jul 12, 2012 06:23 PM
OTD
Jul 4, 2012 11:27 AM
Grouse
Oct 20, 2006 06:18 PM
Saffer
May 15, 2006 03:07 PM
