Question for the 3.0L Owners....
Old Jun 28, 2008 | 10:46 AM
jaymson's Avatar
Default Question for the 3.0L Owners....
In the morning when I start it up, even after sitting a couple of minutes but more so in the morning, I got what sounds like rod knocks almost like I just did an oil change. Is this normal or is this something I should get warranteed?
Old Jun 28, 2008 | 12:43 PM
GeneBopp's Avatar
Default RE: Question for the 3.0L Owners....
Well, rod knocks.... No, that would be bad. Mine does the little valveclatter noise. It is just a few seconds of little clicking noises. I park my car for four or five days at a time, so it does it a lot for the first few seconds.
Old Jun 28, 2008 | 01:10 PM
audiprotein's Avatar
From your description there is nothing good.
BTW, it does the same noise after the oil changes??? I dunno
To be on the safe side, id let someoe check that out.
Old Jun 28, 2008 | 01:12 PM
jaymson's Avatar
Well not completely sure if its rod, but it does making a clangin noise like i just did an oil change
Old Jun 28, 2008 | 03:41 PM
TheAudiAffect's Avatar
that's just valvetrain noise for a little bit before oil is pumped to the top of the engine during start up. its nothing to be worried about unless the noise doesn't go away after about 5 seconds or so.
Old Jun 28, 2008 | 06:56 PM
Flip's Avatar
If it's under warranty definitely let them look at it to make sure nothing is wrong.
Old Jun 29, 2008 | 12:11 AM
auditech79's Avatar
ORIGINAL: TheAudiAffect
Exactly, its completely normal on the 3.0L. Another one of the reasons audi doesn't make the 3.0L engine anymore.
Old Jun 29, 2008 | 09:05 AM
jaymson's Avatar
So this is a bad thing?
Old Jun 29, 2008 | 09:06 AM
jaymson's Avatar
What is all the reasons they dont make a 3.0L anymore?????
Old Jun 29, 2008 | 07:08 PM
auditech79's Avatar
The noise is a normal function of the 3.0L, its mainly the cam adjusters at the end of each cam shaft that are chattering because there isn't any oil in them upon start up, once the oil gets fed through them they quiet down.
The reasons they stopped making them is overwhelming customer complaints, ranging from loud noises, snapped timing belts, coolant leaks from a poor design on the rear cross over pipe, cat converter failures which cost on average $3500 to replace, things like that.
