Question about HIDs
I have read several posts on here about HIDs failing and wanted to know that if the light goes out, how do you know if the issue is with the bulb or the ballast? Is there a way to tell by visual inspection?
Hmm...nope. It doesn't mention anything about troubleshooting except for "In case of replace or repair is needed, please seek help from the nearest professional shop."
I'm not good in electric stuff but read specifically at Could I not just purchase a stronger watt halogen bulb to get a brighter light? and then How long will these bulbs last? And then finally here http://www.jwspeaker.com/hid_information.htm (Google rocks
So i think Ballast just converts the voltage for the HID Bulb. Of course everything can brake, but from those links i'd say Bulbs are like 10x likely to go bad before the ballast.
))So i think Ballast just converts the voltage for the HID Bulb. Of course everything can brake, but from those links i'd say Bulbs are like 10x likely to go bad before the ballast.
speed_racer_801
May 15, 2007 01:26 AM
QU4TTRO
Feb 23, 2007 02:55 AM
