Radiator Cooling Fans?
Old Oct 10, 2009 | 07:13 PM
neabz13's Avatar
Default Radiator Cooling Fans?
A week ago I got the cel. I went and got the codes and then cleared them. The problem I was having was on a cold start the engine wouldn't start up above a thousand rpms and idle a bit before warming up. Well after clearing the codes that problem went away. But now when I turn on the car, SOMETIMES the radiator fans come on. Today it happened and i put on the econ and it stopped. But I tried that later and the fans still went. Does anyone have any ideas what it might be?
Old Oct 10, 2009 | 08:19 PM
Dan1969's Avatar
What are the codes?
Old Oct 11, 2009 | 08:44 AM
neabz13's Avatar
P3081
Old Oct 11, 2009 | 08:10 PM
Dan1969's Avatar
Coolant temperature sensor, replace it is like 20 dollars.
Old Oct 12, 2009 | 10:11 AM
neabz13's Avatar
Thank you sir I'll let you know how it goes after I replace it later today hopefully.
Old Oct 12, 2009 | 12:26 PM
pa4ul's Avatar
if u fix the coolant sensor and it continues odds are its a crack in ur ecu housing.
Old Oct 13, 2009 | 08:16 PM
neabz13's Avatar
Well I fixed it Monday and its been fine since so hopefully everything will stay this way. Thanks guys
Old Feb 28, 2012 | 11:13 AM
Vanou's Avatar
Hi!
What do you mean by a crack in ur ecu housing?
In fact, I replaced twice the coolant temp sensor, tested it (fine) and after a few minutes the engine light shows up....
Thanks
Old Feb 28, 2012 | 11:31 AM
M5S5's Avatar
Tech Certified
Originally Posted by Vanou
Hi!
Thanks
Mr. Hijack the thread , what fault codes do you have?
Old Feb 29, 2012 | 06:34 PM
Vanou's Avatar
I've "17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 008 - Implausible Signal - Intermittent".
Thanks
Sorry for the hijacking... )
dafowler88
Jul 8, 2011 09:03 AM
TheThinker
Feb 1, 2010 05:49 PM
ssbike
Aug 4, 2008 10:19 PM
jgm7507
Oct 31, 2007 07:33 PM
tiffanys68
Jul 28, 2006 02:33 PM
