Radiator Cooling Fans?
A week ago I got the cel. I went and got the codes and then cleared them. The problem I was having was on a cold start the engine wouldn't start up above a thousand rpms and idle a bit before warming up. Well after clearing the codes that problem went away. But now when I turn on the car, SOMETIMES the radiator fans come on. Today it happened and i put on the econ and it stopped. But I tried that later and the fans still went. Does anyone have any ideas what it might be?
Well I fixed it Monday and its been fine since so hopefully everything will stay this way. Thanks guys
What do you mean by a crack in ur ecu housing?
In fact, I replaced twice the coolant temp sensor, tested it (fine) and after a few minutes the engine light shows up....
Thanks
Mr. Hijack the thread , what fault codes do you have?
I've "17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 008 - Implausible Signal - Intermittent".
Thanks
Sorry for the hijacking...
Thanks
