REALLY LOUD FAN NOISE AFTER STARTING?!?!
Hello,
Just lately my fan has been making a really loud noise just after starting my car. It sounds almost like an industrial fan that's blowing really hard. The noise goes away after a few minutes. What could this mean?
B6's don't have engine driven fans, its all electric. When that's happened to me, its been the coolant temperature sender. Bet you throw a CEL in a few days, if so, it almost certainly is. Luckily its an easy fix...
I just recently had the exact same problem. Not only would my fan kick on really loud right after start up, but also usually right when I'd arrive to my destination. Got the CEL, got a coolant temp sensor, got rid of problem. Yay for cheap and easy.
ORIGINAL: lox1985
I got the same problem, but it only happens on cold temps. very cold [
My 04 1.8t did this the other morning. It was COLD (for AZ) and the first time i have heard it on start-up. However, I have a code saying cooling system malfunction (used the v scanner). Temp gauge does not raise above normal mid point. My boosted performance from my chip has disappeared though...strange coincidence?
