Replacing left turn signal bulb
Old Mar 28, 2008 | 09:15 AM
03A41.8T's Avatar
Default Replacing left turn signal bulb
My left front turn signal bulb is out. Does anyone have any information on how to replace it? Is it very hard? How much are the bulbs usually?
Old Mar 29, 2008 | 09:30 AM
A4Boost's Avatar
Default RE: Replacing left turn signal bulb
I have same exact car as you do.I am pretty sure that there are a few write ups on this site but when I had to replalce my Xenon bulbs I found a good write-up with pics on A4Mods.com under the "Clear Corner Mod" link.Now this write-up only tells you how to remove the whole light assembly from the car. Once you have it out, you will see a black cap with about a 1 inch "fin" sticking off the top of the cap. Grab the "fin" and twist the cap in a counter-clockwise manner. The cap will now be loose exposing the bulb that you need to replace. This is a little difficult to explain without pictures, but you get the general idea. i would not imagine that the bulb would cost any more than $8.00 or so at the most. Good luck!
2000greena6
Jan 7, 2012 12:13 AM
abedel2
May 13, 2009 07:53 AM
wutafobbb
Apr 15, 2008 10:23 PM
cricha02
Aug 20, 2005 04:49 PM
FezA4
Oct 7, 2004 09:34 AM
