Replacing rear break light (pas) and front fog light (dvr)
Old Oct 9, 2010 | 12:33 AM
Mischief's Avatar
Default Replacing rear break light (pas) and front fog light (dvr)
Both are dead and I was wondering if it's and easy fix, I drive a 2003 A4 Avant 3.0. I know for the front turn signal and head lights you need to remove the whole front bumper but I was hoping these would be easier since it was $93 in service to replace a $3 turn signal bulb.
Old Oct 9, 2010 | 01:37 PM
ilackav8's Avatar
the brake light is easy.theres a circular access panel on the inside of the trunk with a long screw holding in the fixture. take it out and the whole assembly comes out, then you just have to disconnect the wire.
the head lights are pretty easy (if you or a friend has small hands).just take off a couple pieces to get in there.
for the fog, im really not sure.ive never had to do it so maybe someone else has tips
Old Oct 11, 2010 | 01:41 PM
pa4ul's Avatar
fog just pop off the grills undo the hex bolts and swap the bulb. Just as simple.
davesquash
Jun 6, 2010 08:51 PM
ArmenB
Oct 11, 2008 12:23 PM
Shamboola
Nov 17, 2006 11:16 PM
BoricuaBadBoy07
Mar 23, 2006 03:40 AM
