Right Turn Signal Problem
Old Nov 11, 2009 | 12:24 AM
inkstrat's Avatar
Default Right Turn Signal Problem
I have a 2003 A4 3.0 Quattro and the right turn signal blinks fine (three times) if I tap on it but if I lock it in it first blinks left (twice) and then blinks to the right. This only happens
when I activate the right turn signal.
Please let me know how this can be fixed.
Thanks,
Arjun
Old Nov 11, 2009 | 01:15 AM
Midniteoyl's Avatar
Saw this problem here on the forums.. not sure if it got resolved. Try to do a search..
Old Nov 11, 2009 | 05:18 AM
Dan1969's Avatar
The guy that had that problem posted on Audizine too. His stalk was the problem.
Old Dec 15, 2009 | 04:37 PM
mouse1z's Avatar
Default I'm having same issue on 2004 A4 Quattro
but it has gotten worse. It now continues to signal left instead of right. Still looking for solution.
Old Dec 15, 2009 | 09:57 PM
Dan1969's Avatar
^^ Did you change the stalk yet?
Old Dec 29, 2009 | 12:36 PM
dvmbound1977's Avatar
Mine is having the same problem. It doesn't happen all the time and when I took it to the dealer (under warranty) it magically did not happen. I am living with its intermittent happenings. Let me know if it has been resolved.
Old Dec 31, 2009 | 07:22 PM
mouse1z's Avatar
Default Replaced turn signal switch
I had bought the car used off of a dealer lot. The turn signal started acting up right after I got it, but I was slow to take the car back to the dealer because it was so intermittant. We compromised on me paying for the part and they installed it for free. It was part number 8E0-953-513-4PK and cost $150. They told me the labor would have also been around $150. Appears to have fixed the problem.
Old Dec 31, 2009 | 08:38 PM
auditech79's Avatar
^^^Thats a turn signal stalk if i remember that part number, price it right too.
However B6 A4's have several problems with the turn signals, i beleive i noted it in the sticky i made, not sure.
If the turn signal stalk isn't working and you tap on the fender and it starts working, chances are its the socket the bulb sits in.
If its intermittent, then its the turn signal/hazard relay, if that doesn't fix the issue then replace the turn signal stalk which has a tendency to short out the relay.
BigNasty
Oct 1, 2014 07:45 PM
domvr6
Apr 15, 2014 07:11 AM
mellow
Oct 8, 2008 11:24 PM
mellow
Oct 7, 2008 03:26 PM
mischiru
Aug 4, 2005 12:22 AM
