rought idle, mis fire codes, PLEASE HELP
Old 07-24-2012, 11:15 PM
irunktm's Avatar
Default rought idle, mis fire codes, PLEASE HELP
I have a 2003 1.8t, 140,000 miles. recently on a 200 mile trip it started to idle rought and the CEL came on. It read misfires on all cylinders and a lean code. I smoke tested it and found that the 90 degree elbow in the pcv system was leaking, fixed that, and it still is idling rough, but it didn't through the lean code any more, just random misfires. I cleaned and inspected the MAF, it seemed to be clean but i cleaned it anyways. that didnt change anything. I tried unplugging the MAF while it was running, still idles the same rough way. I'm at a loss as to what to check next. with the car running there is some suction on the oil fill cap, but nothing like what people say they experience when they had PCV problems. What possibility could cause the rough idle. Can a bad coolant temp sensor cause issues like this, how about o2 sensors. I plan on re smoke testing to make sure there is no more vacuum leaks tomorrow. i will also check the fuel pressure to see if the pump could be going bad. i really neeed some help with this one. thank you
Old 07-24-2012, 11:45 PM
z28pete's Avatar
You may still have a lean condition. Usually random misfire is due to a lean condition. You may want to check the fuel pressure.
Old 07-25-2012, 12:24 AM
irunktm's Avatar
okay, thanks. i was also thinking about the upstream 02 sensor, I'll ohm it tomorrow and see what it says but if thats bad could that be causing all my problems?
Old 07-25-2012, 12:11 PM
pa4ul's Avatar
hmm i thinking more along the lines of coilpacks.
Old 07-25-2012, 09:37 PM
Mick300ZX's Avatar
Me too... Just had the same problem and it ended up being a coilpack
dan_j_b
10-10-2010 08:25 PM
liquidxtassy
11-19-2008 10:54 PM
liquidxtassy
11-18-2008 08:00 PM
joeynach
02-18-2008 04:06 PM
Quick Reply: rought idle, mis fire codes, PLEASE HELP
