Serious Ignition Issues
Old Aug 14, 2012 | 05:25 PM
JJC123's Avatar
Default Serious Ignition Issues
2003 Quattro 1.8T. About a month or so ago, I noticed it was missing-mostly at idle. I drove 400 miles on highway and it was fine the entire time. Pulled into the parking lot at my destination and immediately started missing. I jumped out and checked the coil packs by pulling the connectors one-by-one. The misfire was on the second cyl. The CEL was obviously flashing as well indicating a miss. I hooked up the ODB II and it confirmed the miss on the 2 cyl. The plugs had maybe 1500 miles on them, so I assumed it was the coil pack. I replaced the coil pack on the 2 cyl. This did not fix the miss. I replaced the spark plug with a new one-that did not fix the miss. The plug was wet with fuel, so I rulled out the injector. I replaced all 4 coil packs-that did not fix the miss. I then determined since it was not the plug, coil pack, or injector, it must be the connector/wire. I ordered a repair kit and replaced the connector. I also checked all fuses and they were fine. Now the car will not even start. I'm at a loss for what it could be now and just dropped 2k to fix sludging. I'm trying to sell it as I've bought a truck, but I'd like to get it in running condition in order to do so. Any and all advice would be greatly appreciated. Thanks a lot.
Old Aug 15, 2012 | 03:43 AM
headstart101's Avatar
Good luck bro, this forums is about as usefull as a Honda forums to figure out what is wrong with your Audi....
Old Aug 15, 2012 | 06:06 PM
pa4ul's Avatar
was your cel still flashing after u replaced the cylinder 2 pack or was it solid? After u replaced the coils did u scan again to see what comes up now?
Old Aug 15, 2012 | 07:44 PM
Audi Tek's Avatar
Tech Certified
most likely a vacuum leak.
Knock sensors sit right next to cylinders 2 and 4 so they usually the cylinders the record misfires during vacuum leaks.
I'd be looking for a broken check valve on the breather coming off the back of the valve cover.
Old Aug 15, 2012 | 07:47 PM
Audi Tek's Avatar
Tech Certified
You can always PM one of the people listed in the Tech Certified sticky.
My PMs go straight to my work email..... I don't always have the time to browse every post on every forums, I'm sure its the same for other people as well
Old Aug 15, 2012 | 08:39 PM
Well I will do that next next time....Sorry for the rant!
Dylanamer
Jun 26, 2014 10:54 PM
tofast2belast
Sep 19, 2012 06:08 PM
audiA4gm
Sep 6, 2008 02:57 PM
CCA4
Jun 25, 2008 06:28 PM
GeilKyle2
Sep 13, 2005 12:09 AM
