Slow wiper DIY Repair
Old May 9, 2012 | 04:14 PM
diafolwrecsam's Avatar
Default Slow wiper DIY Repair
Okay so i have the slow wiper siezed up linkage assembly problem, im gonna strip it downat the weekend to fix it found some good how to's with pictures etc so faily confident i can do it but here is my question after cleaning all the crap off what is best to re-grease with? Red n Tacky? or Moly grease? adive appreciated
Cheers
Old May 9, 2012 | 05:44 PM
Audi Tek's Avatar
Tech Certified
Good luck.... because it breaks.............. extremely easily.
Old May 11, 2012 | 03:07 PM
MKE_Audi's Avatar
Any good grease that won't break down and flow out of the void. There isnt much space inside the cavity but there is definately a void between the brass sleeves that the spindle is seated in. The whole idea is just like a ball joint, keep the grease in place so moisture can't get to the surfaces and rust. When you disassemble be sure to keep any o-rings and spacers/washers so you can replace as needed.
+1 above, be gentle, it is a fragile and very precise part. the slightest tweak to the wiper arm assembly will have a wiper smacking the windshield or not staying on the surface.
hartsoe1
Oct 15, 2014 06:39 PM
jag1122
Aug 3, 2014 12:49 AM
PurpleNerple
Mar 21, 2011 08:31 PM
TRUK
Mar 4, 2009 08:41 AM
gordond
May 9, 2008 03:10 PM
