Start up and die
Old May 27, 2008 | 07:08 AM
Porsche2AudiHappy's Avatar
Default Start up and die
When I start up my car it almost imediately dies, after sitting for a bit. If I rev it as it starts it will be fine. Anyone have some clues and what to do?
Old May 27, 2008 | 04:40 PM
muckdawg24's Avatar
Default RE: Start up and die
Same problem here, tried replacing the spark plugs, coilpacks and cleaning the MAF sensor. I guess its the starter going, just not sure.
Old May 27, 2008 | 05:09 PM
Karl's Avatar
Do you have a slight air leak post MAF?
Old Jun 7, 2008 | 09:18 PM
I don't think so. I have checked through the intake. And, if I give a bit ofgas at start,it will be fine.
Old Jun 16, 2008 | 03:18 PM
muckdawg24's Avatar
mine ended up being a dirty throttle body. Have it cleaned and see if that helps.
Old Jun 16, 2008 | 03:33 PM
techbod's Avatar
check for fault codes because it could be many things air leaks is a good start and check for bad vacuum lines
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
