synthetic oil grade question?
5w-30 cause the manual said so... they say the car comes with 0w-30 but that's not needed unless you're living in really cold climates. 5w-30 is great for all year use. i think mobil 1 is supposed to be a bit thinner so some people would take the 40 weight.
yea you dont need to worry about 0w-40 unless you live in alaska or the arctic
ive been running mobil 1 for a while and then swithed over to royal purple 5-30 and the motor runs much smoother and easier.
The weight is going to effect the oil pressure and how the turbo spools up. A lighter oil like 0w-30 is going to allow the turbo to spool up much quicker but the oil pressure will be lower since the oil flows much easier.
If you really push the car hard all the time or live in very hot conditions you want to run a 40 weight.
