Temperature Issue - Help Requested
Old Jun 13, 2011 | 09:03 PM
jaemako56's Avatar
Default Temperature Issue - Help Requested
I have an issue with my 03 A4 Avant 1.8T that causes the temperature to drop when driving on the freeway. I seems as though the thermostat is being held open somehow.
I have replace the engine coolant temp sensor and the thermostat assembly. Is there anything else I should look into? Would the radiator coolant temp sensor cause this to happen?
Thanks
Update:
I am at a complete loss. Now my temperature always drops down to the 1/4 mark if I drive >40 mph. I have replace both temp. sensors and the thermostat. Please let me know what I should look into.
Old Jul 2, 2011 | 02:27 PM
jaemako56's Avatar
Updated. Please give me some advice.
Old Jul 2, 2011 | 02:31 PM
02A6Beau's Avatar
I've read a couple of posts that have this same issue. I don't remember seeing a good solution for it though. IIRC it usually comes back to a thermostat problem, either a bad thermostat (test before installing) or something like installing the thermostat upside down (the little ball should be up)
Old Jul 5, 2011 | 12:32 PM
pa4ul's Avatar
have u flushed the system out yet.
Old Jul 5, 2011 | 07:08 PM
jaemako56's Avatar
I have flushed the system.
I didn't think to test the new thermostat but it is the big electronically controlled thermostat assembly, not the usual small mechanical unit.
n2w
Feb 25, 2013 04:29 AM
Deusilan
B7 Models
Oct 24, 2012 07:04 PM
jktt
May 16, 2011 08:45 PM
Tygiganto
Aug 10, 2007 10:34 PM
mleahey28
Nov 20, 2006 03:48 PM
