Terrible trouble - Is my tranny up for a jack :(( Fault code P0722 & P0730
Old 03-13-2008, 09:08 AM
dark_wing_duck's Avatar
Default Terrible trouble - Is my tranny up for a jack :(( Fault code P0722 & P0730
Hi Guys,
Had some trouble driving my A4 recently. This is B6 model which was pretty fine till now and has been taken care of well.
Trouble: Once I had few judders when I applied brake. It drove fine for few days after wards and suddenly one day when i was driving at the speed of 40Kph it suddenly got out of gear - no response to acceleartion. Itried reversing after stopping - got success. Tried again for few hundred meters and it stopped responding to acceleration again
Following is the detail:
Fault Code:
17108 - Transmission Output Speed Sensor (G195): No Signal
P0722 - 32 - 10 -- Intermittent
17114 - Gear ratio Monitoring: Incorrect Gear Ratio
P0730 - 16-10 - Signal Outside Specifications - Intermittent
P0730 - 16-10 - signal Outside Specification - Intermittent
How serious is that ? Is my tranny upfor aJack ? Is there any work around ??
I took my car to a non authorised but highly recommended euro car specialist.
At the end I couldn't trust what he said, h kept changing his words. Anyways this is what he said:
Initially he told me "it seems transmission module need to be changed - its worn out. Cost $8200 plus labour"
My obvious reaction was of shock. So he gave me another posible logic -" probabaly sofware has gone corrupt so the speed sensor is conflicting with gear module readings "
I waited for couple of more days and he gave me a call saying that he has reinstalled the software ( which i seriuosly doubt, no where mentioned cost of installation onreciept???)- it should not give any trouble and probably tranny is not as worn out as well. However, if you get stuck again come back and i will change the computer module. Cost $ 3500
I am totally confused ???
DSMBoost
09-01-2014 10:20 PM
millenia
12-27-2010 01:27 PM
DSMBoost
07-17-2010 04:08 PM
shmeker
06-24-2010 04:50 PM
Quick Reply: Terrible trouble - Is my tranny up for a jack :(( Fault code P0722 & P0730
