thermostat or temp sensor
Old Feb 8, 2010 | 12:01 PM
fullcollapse318's Avatar
Default thermostat or temp sensor
a couple days ago my check engine light came on n i noticed my temp was running at a 1/4 instead of 1/2 and we got a blizzard two nights ago n i got stuck well in the troubles of getting out it flashed coolant then temp went to hot real quick i let it cool down n now if im driving it will stay at a 1/4 if im idling long it will creep up havent seen it go to far past the 1/2 mark i gotta get a hood latch handle so im trying to order all the parts in one shot any suggestions i cant afford a dealership to fix it its a 03 a4 1.8t fwd
Old Feb 8, 2010 | 12:18 PM
bbboy's Avatar
Member
Most likely Temp sensor, mine also ended up with CEL.
But 10k later, my thermostat went, and symptoms were - T would go to 1/2 only in stop-and-go, drop to 1/4 on a hwy.
Old Feb 9, 2010 | 12:32 PM
pa4ul's Avatar
the temp sensor is an easy fix. Located at the rear of the engine being held in by a small plastic pin. http://www.a4mods.com/index.php?page...tml&category=5
Old Feb 9, 2010 | 05:26 PM
Onelucke1's Avatar
It sounds like either your lower temp sensor by the radiator drain or your t-stat. Just went through the same thing. I opted to order parts for $150 (both temp sensors & T-stat) and paid $150 for install of all and new coolant fill/flush. There is a DIY for the T-stat and temp sensors, I just did not have the time. Good Luck
Old Apr 28, 2010 | 05:57 PM
smyte's Avatar
is this in the same spot for the 3.0? I just got my new sensor in and I want to change it later this evening, however I could not find it on my 3.0 earlier when I was looking for it. Any help would be appreciated.
Old Apr 28, 2010 | 10:09 PM
gsimms's Avatar
Yes, and it is tough to get to. Be careful with the plastic clip.
Mckayiva4
Dec 10, 2010 06:39 PM
toboater
Oct 26, 2010 12:15 PM
nikovision
Jul 15, 2008 09:19 PM
gordo79
Apr 26, 2008 08:28 PM
Milky
Nov 3, 2005 10:26 AM
