thermostat or temp sensor
a couple days ago my check engine light came on n i noticed my temp was running at a 1/4 instead of 1/2 and we got a blizzard two nights ago n i got stuck well in the troubles of getting out it flashed coolant then temp went to hot real quick i let it cool down n now if im driving it will stay at a 1/4 if im idling long it will creep up havent seen it go to far past the 1/2 mark i gotta get a hood latch handle so im trying to order all the parts in one shot any suggestions i cant afford a dealership to fix it its a 03 a4 1.8t fwd
the temp sensor is an easy fix. Located at the rear of the engine being held in by a small plastic pin. http://www.a4mods.com/index.php?page...tml&category=5
It sounds like either your lower temp sensor by the radiator drain or your t-stat. Just went through the same thing. I opted to order parts for $150 (both temp sensors & T-stat) and paid $150 for install of all and new coolant fill/flush. There is a DIY for the T-stat and temp sensors, I just did not have the time. Good Luck
Yes, and it is tough to get to. Be careful with the plastic clip.
