Thinking about buying 1.8T B6, is it more reliable than S4 B5?
I'm looking to spend around $12-$14k on a 5-speed Avant. I've found a '02 1.8T with 85k on it or I could get an 01 S4 Avant with 99k on it for similar money. Which would be more reliable, if both cars have been taken care of and are in similar condition? I'm worried about turbo problems and large maintenance costs with the S4, plus I like the B6 body better. Just wondered if there were any major improvements from B5 to B6 in general?
This question is really a no brainer and even S4 owners will telly ou, maintenance on a B5 S4 gets really expensive. A lot of work that has to be done if/when things go wrong require pulling the motor, including when turbos go bad and they will go bad. The 1.8T doesn;t have that problem, the turbo lasts pretty long and is not hard ot replace. The main thing you have to look out for on a 1.8 is sludge, blowing coilpacks and timing belt/water pump. As long as the oil has been changed with the larger oil filter you are good. Also make sure the belt has been changed or change it as soon as you buy it, also not a hard job and keep at least one spare coilpack in your trunk.
Just go with a B6 S4, the 4.2L doesn't have a timing belt, or any of the other problems A4's have. They just use 9 quarts of oil! The B5 S4 is a maintenance hog to say the least, very expensive to keep running.
rami
Mar 18, 2012 02:51 PM
What engine is more reliable the 3.0 or 2.7T, and does reliability matter to whom ever is buying A6?
2.7 turbo turbo
Oct 3, 2007 05:25 PM
s thinking about buying the allroad. What do u guys thinMy Uncle is thinking about buying an allroad
apg96
Jun 10, 2005 08:56 PM
18t, 2008, a4, audi, b5, b6, belt, cost, maintenance, reliable, reliableforums, s4, timing, unreliable
