Trunk won't open
Old May 26, 2009 | 09:50 PM
krider's Avatar
Default Trunk won't open
I have a 2004 Audi A4 Cabriolet that the trunk won't open. I tried the key fob, the door switch and the trunk key and it makes the accuator noise but won't open. I have tried push and pulling while I was doing with no luck. Does anyone know of any emergency ways to get it to open or have a suggestion to how to get to work without bringing into the dealer? Thanks in advance...
Old May 27, 2009 | 01:43 AM
SrK's Avatar
SrK
just use your key.... You can't see the key hole when standing up though...
Old May 27, 2009 | 08:47 AM
krider's Avatar
that's what I was referring to in my post about using the trunk key with no luck so that didn't work either. Any other thoughts out there???
Old May 27, 2009 | 11:33 AM
Myst420's Avatar
You shouldn't hear an accuator noice while using your key. Its strickly mechanical. (at least that is how mine is...maybe the cabrio different). With mine, if I turn the key clockwise, it locks the trunk. Counter-clockwise unlocks and opens the trunk at the same time.
The only other thing I could suggest would be to lower your back seats, crawl into the trunk, and pull the emergency release lever that on the inside of the trunk lid.
Old May 28, 2009 | 09:21 PM
prizrak's Avatar
Had the same problem and emergency release didn't work either. It started working after about 20 mins of driving not sure why...
Old May 29, 2009 | 08:12 AM
Myst420's Avatar
That's wierd....maybe the hinge gets jammed somehow?
Old May 28, 2013 | 12:31 PM
Audi/BMW/Fan's Avatar
Default A4 Cab trunk won't open
I have this problem with my S4 Cab and it occurs only when the car has been in the sun. The activator sounds like it is being triggered but the trunk won't open. If I let it cool down in the garage or in the shade, the trunk will then open with the fob. Something must be expanding and restricting the proper operation of the activator or something that releases the latch.
joshy_squash81
Aug 1, 2012 09:36 PM
Schwaan
May 29, 2009 07:45 PM
cbouslim
Dec 25, 2008 11:48 PM
Pete_SI
Aug 14, 2007 12:52 PM
Shefford
Apr 22, 2006 02:51 PM
