vag-com problems
Old Apr 27, 2011 | 02:12 PM
jacko7069's Avatar
Default vag-com problems
Hi all very new to this, I have an Audi A4 cabriolet, 2003 B6, 3.0 V6, whilst driving home the other day the ESP light came on, parked the car up for the night, next day started and engine management light came on to, car stalled at juctions. Checked all fuses and no 34 fuse blows everytime i turn ignition key to start, plugged in vag-com and listed below is the results, can anyone help please?
Chassis Type: 8H - Audi Cabrio B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
65 67 73 75 76 77
VIN: WAUZZZ8H83K022121 Mileage: 117690km/73129miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 H HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0011584
Shop #: WSC 00672 785 00200
VCID: 3A702E6C0CD9
11 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 002 - Lower Limit Exceeded
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded
17923 - Intake Manifold Valve (N156): Short to Ground
P1515 - 002 - Lower Limit Exceeded
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 002 - Lower Limit Exceeded
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 002 - Lower Limit Exceeded
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 002 - Lower Limit Exceeded
17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
P1140 - 002 - Lower Limit Exceeded
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 002 - Lower Limit Exceeded
17527 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1: Short to Ground
P1119 - 002 - Lower Limit Exceeded
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 CS
Component: V30 01J 3.0l 5V RdW 3011
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Many thanks Clive
Old Apr 27, 2011 | 02:38 PM
pa4ul's Avatar
im wanting to say ur coilpack harness cracked and is grounding out somewhere? That would be a guess though. im judging this by the fuse blowing but cant remeber if its fuse 29 or 34 that blows when the harness goes.
Old May 4, 2014 | 09:33 PM
Michael93508's Avatar
Default Need Help Same Problem
Hey Jacko7069, could you please tell me how you ended up solving this problem you had with your Audi because i have the same exact problem for my car. I have the same car as you, year make and model and I am experiencing the same problem as you and cannot figure out how to fix it. Could you please tell me in detail what you did to fix your car? If you could, I would really appreciate it. Thanks man.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
