Vibration on acceleration
Old Dec 13, 2011 | 09:17 AM
d21burggraf's Avatar
Default Vibration on acceleration
For nearly the last two weeks I have had some vibration issues. It only seems to occur after I have reach about 40mph and up. When I try to speed up thats when I notice the vibrating. As soon as I let off of the throttle, it goes away. I do not have an engine light on or notice anything else performance wise. Any tips or suggestions that I could try? My car is a 2004 A4 1.8T FWD.
Thanks!
Old Dec 13, 2011 | 11:03 AM
careercadaver's Avatar
I had a similar issue when I was over 60 that seemed to disappear upon braking. Ended up being my tie rod end. It could also be a wheel that is out of balance. I'd make sure a weight didnt come off one of your wheels. There's a lot of things it could be man. Could be a drive shaft or even a loose wheel, loose caliper, etc.
Old Dec 13, 2011 | 11:08 AM
jdahlen24's Avatar
^^ Agreed. One thing you could do is put the front end up on jack stands and grab each wheel at the 3:00 and 9:00 position and try to wiggle the tires. There should not be any play. If there is, you probably have a loose tie rod end or control arm.
But it could be many things, as noted above.
Old Dec 14, 2011 | 08:33 AM
Thanks for the help. My car only vibrates though when the gas peddle is pressed. It doesn't vibrate at all when I am just coasting or going the same constant speed, only when I speed up. Again, only seems to do it after I hit around 40-50mph.
Old Dec 14, 2011 | 09:23 PM
ImTheDevil's Avatar
Seen this on a couple of cars where it turned out to be a bad inner or outer CV joint too.
Old Dec 15, 2011 | 09:39 AM
Thanks man, you may have nailed it. I think my passenger-side inner CV boot has a tear in it. I appreciate all the help and suggestions!
cburneko
May 28, 2017 08:37 PM
Klaus_Meine
Jan 22, 2015 07:11 PM
bmparis
Sep 4, 2013 05:47 AM
xxbmxlsxx
Jan 1, 2009 05:13 PM
Allroad6M02
Jan 19, 2007 02:45 PM
