Window Issues
Old Apr 14, 2009 | 10:43 AM
ggspeed860's Avatar
Default Window Issues
My passenger side front window makes a grind when you put it up or down. I feel like its off the track. How do i get the door panel off this thing? I can see the screws, but don't know if I'm missing anything or any of them.
Any tips?
If this helps, Its a 2005 1.8t Quattro.
Old Apr 15, 2009 | 11:20 AM
kchao2000's Avatar
There are should be total of 6 screws for the front door panel. 4 behind the wood trim (if you don't have wood trim, then they are behind the sliver door trim), 1 behind the door handle (you will see a hole under the door handle, look up from the hole you will see a screw there), and 1 at bottom of the panel (all the way down, right in the center).
To remove the door trim, use a flat screw driver and pop it little bit (just a little gap, don't pop it too hard) from the side near by rear view mirror, then you can slide it out. After you have removed all 6 screws, just pop the door panel along the edge. There are about 5 plastic clips holding the panel. Once you pop the panel loose, then just lift it up the panel should be off.
I recommend you get some new plastic clips handy because most likely you will break some while poping the panel. Also, do it with window roll down.
Old Apr 15, 2009 | 03:03 PM
kwik_shift's Avatar
The window regulator is probably shot.
Old Apr 16, 2009 | 02:55 PM
xSilent13x's Avatar
A new sticky has been added to the B6 forums at the top of the thread list. Its a great DIY for window regulators.....Finally! Props for that guy...!
tomclrk5
Nov 28, 2010 09:49 PM
The_n
Jul 2, 2010 10:23 PM
maxxstl
Jan 17, 2008 12:52 PM
jglover
Nov 24, 2006 03:30 PM
METALHEAD
Jan 8, 2006 05:16 PM
