Window regulator or motor?
Old Oct 25, 2009 | 03:37 PM
knerml's Avatar
Member
Default Window regulator or motor?
I am having problems with my driver side front door window.
The window is having problems going up and down.
There are cracking noises comming from around the motor.
Winow seems to be tracking OK.
Any opinoins on whether this is the motor or regulator?
I'm thinking regulator.
Working the window up/down loosened things up a little bit. The noise now mostly occurs just as the window is going up, and a couple of inches from closing.
Thanks,
Mike
Old Oct 25, 2009 | 04:28 PM
shane.trammell's Avatar
When the regulator breaks the window will roll down with the motor but not up. It
will also gradually slide down on it's own.
Old Oct 25, 2009 | 10:51 PM
Dan1969's Avatar
Also normally cracking noises is the regulator.
Old Oct 26, 2009 | 08:26 AM
knerml's Avatar
Member
Thanks!
Old Oct 26, 2009 | 05:32 PM
OKIE's Avatar
Hey guys! What about a window that wont go up or down with the button, but will go up or down with just using my hand? It wont go all the way down! Only till 1/2 way down! I can hear something wove (motor or regulator) but it dosent work!
Old Oct 26, 2009 | 11:09 PM
That's prob the regulator too.
Old Oct 27, 2009 | 05:29 PM
OKIE's Avatar
Thanks Shane!
Old Nov 2, 2009 | 12:03 PM
bullsaudi's Avatar
The window doesnt go up or down and before this happened there was lot of squeaking and cranky noises. Like thing is getting crushed inside.
Should i buy the both regulator and window or is this just a regulator. I am buying the parts and later get them fixed by someone who can do a DIY at home.
Any suggestions??
Old Nov 4, 2009 | 03:25 AM
Dan1969's Avatar
You could probably do it yourself. Check A4mods.com or AudiDIY.com, there's plenty of them there. Or there's also a sticky posted by Auditech79 on the top of these forums.
mtnxtreme
Dec 7, 2011 07:52 AM
vtraudt
Dec 16, 2010 08:43 AM
INeeDTurbo
Apr 26, 2008 11:31 AM
littleflavio
Feb 27, 2008 10:45 AM
Restrepo
Feb 6, 2008 07:24 PM
