Wiring Sub's and Amp for my car
Old Feb 23, 2015 | 08:47 PM
Brandnewguy's Avatar
Default Wiring Sub's and Amp for my car
I have a 2004 Audi A4, I already have an aftermarket deck installed and i'm gonna try and wire the sub's and amp tomorrow. I have all the tools i'll need as well as an amplifier wiring kit. The main question I have is where is the best place to run my power cable from the battery to the deck? I watched a video on youtube and the guy ran it through the door jam but I heard that can be dangerous. Feel free to give me any general tips & tricks as well because this is my first time wiring a car for subs.
Thanks guys
Old Feb 23, 2015 | 08:49 PM
Also another question I have is do I have to disconnect my old stock sub when I wire up the new ones? I have a stock one in the back I think its like an 8 inch or maybe even 10. I'm wiring two ten's in a box into the trunk.
Old Feb 24, 2015 | 06:00 PM
pa4ul's Avatar
do disconnect the stock sub. OR you will be left with rattling. I had my power wire run along the door channel then thru the gromment in the firewall to the batt.
Old Feb 25, 2015 | 09:30 PM
I'm having a really tough time getting it through the firewall..any way you could be more specific about how you got it through there? thanks man
Old Feb 26, 2015 | 12:07 AM
ajlopina69's Avatar
In the fire wall on the drivers side to the left of the ecu lower section, and run your sub? Not your deck from the battery ....and you can run your rem wire from the factory amp just test the wires to see which on gets 12v when the ignition is turned on , and run your wire along the floor board and under your back seat into the trun area
vtraudt
Oct 10, 2013 01:33 PM
audi908
Mar 11, 2010 05:42 AM
tmanley
Aug 26, 2009 10:58 PM
Mya4T
Oct 23, 2007 06:15 PM
highbeam
Jul 19, 2006 11:18 AM
