06 audi a4 s-line 2.0 Is my transmission screwed?
Old Jun 20, 2011 | 12:17 AM
idnafox's Avatar
Default Need mechanical advice on my 06 A4!! Please help
I have a 2006 Audi A4 S-line front wheel drive with the 2.0 turbo and automatic transmission. I don't have any warning lights on but the car sputters when taking off up to 20 or 30mph and when coming to a stop under 5 mph it sputters and acts like it is going to die. Also, when in reverse, it also cuts out. I have tried shifting into nuetral when coming to a stop and it gets rid of the problem. Also, if i only apply the brakes softly when stopping, it isnt as bad. Took to a foreign car mechanic here (no audi dealer for 2 hours away) and he full scanned the car and got zero codes. Again, there are no warning lights of any kind. Thanks for any help.
Old Apr 12, 2013 | 12:20 PM
darawsheh's Avatar
Dear
Check the transmission fuile level.
BEst
Old Apr 12, 2013 | 08:04 PM
sincityaudi's Avatar
If you have never serviced your CVT transmission, which is every 35K miles, then you have most likey burned up the fluid and have since destroyed the clutches or the internal varator and chain. The only other thing I would consider is trying pulling off your oil fill cap while the car is at all... If it is very hard to pull off then most likely you just need a PCV (crankcase pressure regulating valve) and the turbo vent hose which is the big metal encased hose from the top of the turbo to the valve cover. If it does come off easily then you most likely need a CVT trans unfortunately.
Boostaholic28
Mar 15, 2014 10:11 PM
spotcar22
Apr 29, 2010 05:01 AM
Mhmara
Jun 29, 2009 10:36 PM
Audinick81
May 20, 2008 02:55 PM
natefanaro
Mar 29, 2008 12:23 AM
