07 Audi A4 Sline Engine Problems
Old May 19, 2017 | 11:48 AM
sheldon's Avatar
A lot of these codes remind me of my dying battery I encountered on my C5 A6. The battery was slowly giving up and causing all kinds of weird errors and voltage issues / ecu communication problems, etc.
How good/new is the battery? If older and a battery tester shows it's below 50% capacity it's time to get a new one, reset the codes and see what comes back.
I also would check the wiring from/to the ECU and make sure it does not have any damage.
If the ECU errors still come back I would have to agree that maybe you should check the computer as you should not be getting errors from it if something mechanically is failing.
Old May 19, 2017 | 01:35 PM
Audi-a4sline's Avatar
sheldon,
Thanks for the input I had been told the battery was replaced recently but I think I'll have it checked to make sure it's not low on a charge. I did clear the cluster of codes from 05 yesterday and it took out my EPC light. I'm gonna clear the rest today and after I get coolant and fix a oil leak I'm gonna take my car for a drive and see what comes back. I checked the air pressure regulator and it doesn't seem cracked so I will be checking the wiring to/from that as well. Have you ever checked wiring? Not too sure hot that's done/where it all goes. Gonna google and find a wiring diagram of the car today to further troubleshoot. Anyone ever flashed a ECU to stock? I'm wondering if there was a remap or bad flash done to it.
Old May 19, 2017 | 05:44 PM
KingWulfgar's Avatar
Also, VAGCOM codes can be finicky. Did you clear them and see if they came back? I would definitely try that as well. It does sound a lot like when these cars start freaking out due to low voltage.
Old May 19, 2017 | 10:01 PM
clesred codes and ran for about 15 min, ECP light is still on but no CEL yet, car still drives just as bad. Haven't had a chance to check battery charge. Took my ECU out and heard it rattle sounds like something may have fried inside and broken off these things are sealed pretty tight I can't imagine anything getting into it from the outside I couldn't even open it..
Old May 19, 2017 | 10:02 PM
cleared codes, checked ECU and heard a rattling inside, couldn't get it open but I think something shorted and came loose inside.
germancarlover
Oct 31, 2014 01:41 PM
COOMBY D
Feb 12, 2014 04:57 AM
indika_00
Jul 14, 2008 01:25 PM
eugrub
Mar 31, 2008 11:13 PM
ippolitof
Feb 7, 2007 12:35 PM
