2005.5 A4 2.0t Fuel pressure problem
Old Nov 3, 2013 | 02:54 PM
ninjewx's Avatar
Default 2005.5 A4 2.0t Fuel pressure problem
Hey guys,
This is my first post here. I got a CEL on about a year ago and my car would not go past 3k RPM, so I brought it in to a German repair shop. I ended up having the fuel code p2293. It ended up being my HPFP which I got replaced. That fixed that, however, after they replaced it I still had code p310b. Took it back to the same placed and they replaced the following:
1. Low pressure fuel pump (3 times to make sure I didn't have faulty one)
2. Fuel filter (twice to make sure it wasn't faulty)
3. Fuel pressure control module that is above the LPFP
4. Fuel pressure sensor
I still have a check engine light and they basically told me they I have no idea. I was out of options so I took it to the dealer, left it there for 3.5 hours of diagnostic time where they supposedly checked everything including the wiring. They told me they have no idea also. I'm completely out of options and I can't pass inspection with that light on in my state.
Old Nov 4, 2013 | 09:09 AM
M5S5's Avatar
Tech Certified
There is a whole update for the high pressure fuel problem. The pump , intake camshaft , piston & chain tensioner all get replaced , not just the pump. You might want to try a different shop fimiliar with Audi's.
Old Nov 5, 2013 | 09:51 AM
ninjewx's Avatar
When I got the pump replaced they also did all that, sorry I wasn't very clear in my original post. I've taken it to 3 different German repair shops, and the dealer. I still have the code p310b.
Old Nov 12, 2013 | 11:49 AM
Cfidave's Avatar
I had the same 310b CEL on my 2006. It ended up being the lpfp, in the gas tank, under the rear passenger seat. I used Vagcom to check the low pressure fuel values at idle, which should be around 5 bar. The duty cycle of the pump at this point should be well below 70%. Mine was 5.1 bar and 54% with the new pump and 4.4 bar and 76% with the old pump. If you can verify these values with Vagcom it will rule out the fuel pump, and/or its' connections ( I know it's new ) .
If you changed the HPFP and LP sensor then they should not be what is causing the problem. The other possibility is a worn cam shaft follower, or worn cam lobe that the HPFP piston rides on. I assume they checked that when they replaced the HPFP.
The other possibility is a blockage somewhere in the fuel system. Could be a hose kinked or bent. Again, you would see this with Vagcom, looking at low pressure fuel values. If you are not throwing evap codes, it is probably not a leak.
I have found that Vagcom is a must with these cars, just too many systems to try and trouble shoot without some help to point you in the right direction. This code is a royal PITA, I hope you can get it solved.
Old Nov 18, 2013 | 05:10 PM
ninjewx's Avatar
Thanks for the reply. I am bringing it in Thursday to a place to have them look at everything again. I find it hard to believe that it's a low pressure fuel pump issue. I've had 4 total in my car to make sure it wasn't the LPFP.
Old May 1, 2014 | 04:27 PM
achikuda's Avatar
Default same here
I'm just wandering what has happened how the story finished?
I just have the same issue. :/
At the moment it takes quite some time to (like 10 min.) build up the pressure to normal.
but at the beginning, on cold start it is low :/
I changed sensor... and filter... and as long as I know my pump that is located under back seat is comparatively new (updated version with three pips instead of two)
pump it self is quite expensive, I've been quoted 580$ with labor
so want to be sure that pump will solve my problem
Old May 6, 2014 | 11:04 AM
ninjewx's Avatar
Hey it ended up being the low pressure fuel pump. After it getting replaced 3 times, I took it to a place near my house who said it had to be low pressure pump. I told them it has been replaced 3 times and looked at again to make sure it wasn't that pump, but they still said it was faulty. They replaced it (this is my 4th one) and the light hasn't come back on.
Old Nov 26, 2018 | 02:01 PM
Luis Castillo's Avatar
hi, do you know if there is a way to test the fuel pump module? Mine is a 06 A4 2T Fwd. Thenk you!
betyouaint
B7 Models
Apr 29, 2021 08:04 PM
Elias S Iluvuras
B7 Models
May 16, 2017 02:50 AM
saifxnyc
Oct 9, 2015 05:21 PM
AudiGirl92
B7 Models
Dec 11, 2013 10:53 AM
Jayjay
Feb 14, 2008 03:47 PM
