2005.5 Audi A4 B7 Battery Replacement
Old Feb 15, 2019 | 08:00 AM
Rob Strongin's Avatar
Default 2005.5 Audi A4 B7 Battery Replacement
i was wondering if someone could provide me with some clarification regarding battery replacement in a 2005.5 (B7) A4 as there is much conflicting information out there on this issue.
When replacing batteries in other cars I have owned I usually use a battery saver connected to the OBDII terminal (or cigarette lighter) to prevent power loss to radio etc. My A4’s battery needs replacement and I’m cautious in doing it myself as info I have seen seems to indicate the radio, keyfob and other re programming will be necessary. Can someone advise me if a battery saver connected to the OBDII terminal makes the battery replacement “plug and play” without any type of reprogramming?
It also seems from what I read that the Audi OEM battery (my car is on its second OEM battery) has a vent tube connected to it that aftermarket batteries do not include. Is that true?
Any help in these questions would be greatly appreciated.
Old Feb 17, 2019 | 01:19 PM
rhodes991's Avatar
Just replaced mine (well, had Walmart due it). I had my battery disconnected and didn't lose any programmed items (radio for example). After the battery was replaced I did have to reprogram my clock, but that was it. Mine did not have a vent, but I did see that some do. Guessing that the replacement doesn't need it.
Old Feb 17, 2019 | 01:33 PM
Thank you.
stubird
Apr 17, 2012 10:25 AM
krimsanavenger
Feb 20, 2011 06:47 PM
vmaxie
Feb 9, 2010 12:01 PM
pherbolario
Feb 14, 2008 03:55 PM
dudley doright
Aug 10, 2005 11:29 AM
