2007 A4 accelerator sensitivity
Old Mar 4, 2012 | 01:41 PM
dbdezyne's Avatar
Default 2007 A4 accelerator sensitivity
Not sure if this is an issue or not, but it seems that there is not a smooth transition to acceleration when slightly pressing on the pedal. While pressing a little more then the car picks up rather briskly, but not really strong. I understand these autos use a electronic signal from the pedal, so not sur if something is out of whack with the pedal electronics or maybe something just needs to be recalibrated. I have vag-com so any ideas would be appreciated.
Old Mar 5, 2012 | 09:21 AM
eMacPaul's Avatar
What transmission do you have? The CVT (multitronic) is known for having a little jerk when you start moving.
Old Mar 5, 2012 | 10:44 PM
dbdezyne's Avatar
Yes, it's a CVT. Its not really bad but just noticeable when beginning to accelerate. Seems like there should be a smooth transition.
Old Mar 6, 2012 | 09:47 AM
esandes's Avatar
Banned
when you push down harder the transmission downshifts a gear or two which will cause more thrust.
Old Mar 31, 2012 | 11:06 PM
mhoward's Avatar
On mine, that I've had for just about a month, I noticed that same thing. I think its just shifting from 1st to 2nd gear. When I'm at a stoplight and got to accelerate lightly like you described, it starts out in 1st then shortly thereafter it feels like it stutters when it shifts to 2nd. I think this is normal, maybe i'm wrong....
Old Apr 1, 2012 | 07:31 PM
Audi Tek's Avatar
Tech Certified
A CVT doesn't have gears.... and he stated it happens during slight accelerating, Not mashing on the gas pedal
Old Apr 2, 2012 | 04:13 PM
irussel's Avatar
same thing occurs on mine, 2008 2.0t w/ CVT. just gotta take it easy on the accelerator between 0-20mph if you want a smooth start, but even then it can still be jumpy.
infomad
Feb 4, 2011 03:48 PM
magic.man
Sep 22, 2009 02:27 PM
assegai
Nov 24, 2007 03:44 PM
m5racer
Feb 5, 2007 08:45 PM
twinturboluigi
Sep 4, 2006 07:56 PM
