A4 b7 2.5tdi turbo (vacuum) fault
Old Apr 20, 2013 | 01:02 PM
richieski's Avatar
Default A4 b7 2.5tdi turbo (vacuum) fault
Hi all,
I have a Audi tdi 2.5 B7 A4 sline turbo actuator movement incorrect. Can anyone help? I have 2 fault codes p1654 (replaced coolant temp sensor-done) 01318 no communication injection pump. I have measured resistance of n75 around 17 ohms, 8.9 vdc supply to n75. As you can see the actuator stays at the stop screw. I have tested full movement of actuator with hand vacuum pump and egr valve. The vane arm springs back very quickly doing it manually so no sticky vanes
Audi tdi 2.5 B7 A4 sline turbo actuator movement poor - YouTube
bradyhn
Jul 19, 2014 08:53 PM
redmond1501
May 12, 2014 02:55 PM
Norwegiandude
Aug 1, 2013 05:27 PM
Ant5254
Nov 10, 2012 09:20 AM
Rufio-plb
Dec 2, 2008 10:50 AM
