access to brake bulb replacement on A4 Avant
Old Aug 15, 2011 | 11:53 AM
mgs's Avatar
mgs
Default access to brake bulb replacement on A4 Avant
How do I get access to the in-fender cluster to replace the brake light bulb? and is this the same bulb used for the (upper) turn indicator?
Old Aug 31, 2011 | 08:31 AM
redcon1's Avatar
I hope you figured this out by now, but there is a small circular cover on the side trim you have to pry off. Then you can unscrew a bolt with a slotted screwdriver or big allen wrench, which allows you to pull the assembly away.
Joe Mazza
Jan 24, 2012 12:31 PM
ttjenny
Aug 2, 2010 01:30 AM
gson
Mar 27, 2008 09:57 PM
Flarika
Jul 5, 2007 01:21 PM
ttjenny
Sep 3, 2005 07:28 PM
