Amp Location
Old Oct 4, 2010 | 04:40 PM
Helras's Avatar
Default Amp Location
Maybe i'm a dummy, but I cant find the amplifier for the speakers.
I have an '08 a4 with the audi symphony (not the bose system). I was under the impression it had an amp for the speakers, does anyone know where it is?
On a side note, I'm going to be putting in a new headunit with a built in amplifier, anyone know if the stock amplifier will cause problems?
Old Oct 5, 2010 | 10:25 AM
KingWulfgar's Avatar
It won't cause problems as long as you know what you're getting into. In cars I've dealt with in the past, you had to get the right wiring harness for how you wanted to wire it. You either use the preamp outputs on the head unit and wire it into the factory (or a new, standalone amp), or you get a wiring harness that bypasses the factory amp and use the amplified outputs on the head unit.
Either way is acceptable, just don't run the amplified outs into the factory amp. I'm new to my Audi, so I don't know much about the Audi factory amps, so I can't tell you whether you should bypass it or use it--someone else will have to get into that.
joshf
Oct 28, 2008 10:09 PM
saltwatergold
Dec 17, 2007 01:38 AM
ukaudia6
Dec 11, 2007 03:08 PM
Yeff24
Nov 21, 2007 12:23 AM
audi416
Mar 19, 2006 11:53 PM
