Audi 2007 A4 Brake Bleed
Old Apr 23, 2011 | 06:42 AM
sherlock59's Avatar
Default Audi 2007 A4 Brake Bleed
Attempting to bleed the brakes with power bleeder.
Right rear has continues flow of air bubbles
Left rear has solid stream of brake fluid
Right front has light flow of air bubbles
Left front has solid stream of brake fluid
No visible leaks.
Power bleeder holds 10 Psi pressure for extended period of time with no drop.
Brakes work fine and car does not veer to the right or left when applying brakes
What is causing the air bubbles?
Old Apr 25, 2011 | 08:03 PM
BoschServiceUS's Avatar
Default Have you thought about the condition of your brake fluid?
Did you know brake fluid absorbs water? Water lowers the boiling point of the brake fluid. Heavy brake use, as in going down a mountain pass, can cause the water in the brake fluid to boil causing loss of braking. Brake fluid also protects expensive Antilock brake system components. Most carmakers recommend changing/flushing the brake fluid every two years, some recommend yearly.
Experience the Bosch Difference.
Find out more, and tell us what you think? We’d love to hear from you!
http://www.boschservice.com
http://www.facebook.com/BoschServiceUS
http://www.twitter.com/BoschServiceUS
* Content provided by Bosch Service Center Specialists,
Kurt Andersen's Foreign Car Service ltd.
16289 West Colfax ave.
Golden, Co. 80402
Old Apr 26, 2011 | 11:42 AM
Audi Dan's Avatar
Sherlock:
Wow, I am going to get jumped on after telling you this. Lots of folks love those power bleeders because they are easy to use.
I have used a power bleeder in the past and found the one I used to be less than optimal. It took forever to change the fluid, and used far more fluid than it should have. The reason, I think, is that the flow is slow small it really doesn’t flush out the old stuff or air very quickly. I have since resorted to the old fashioned two person method.
Now to your problem. I’m guessing you do have some air in the lines, and perhaps it is being caused by the power bleeder. You could have an internal leak inside the power bleeder jug, or at the top of the feeder tube. I’d do an old fashioned bleed on all four wheels to see if you still have air.
Good luck
redmond1501
May 14, 2012 03:45 PM
makav3li
Apr 18, 2010 10:52 AM
suitbandit
Apr 12, 2007 12:15 PM
edkwok
Jan 29, 2007 01:49 AM
Diavan
Dec 20, 2005 02:51 AM
