Audi A4 B7 Codes
Old Jul 27, 2017 | 09:31 PM
Rich Bezus's Avatar
Default Audi A4 B7 Codes
Hi, I own an Audi A4 B7 2006 2.0T Quattro and my car had been misfiring for about over a week so I thought. Ended up being something wrong with my MAF (mass airflow sensor). I bought a dealers sensor and changed it and my car still has problems running it sounds as if it's coughing. Whenever I step on the gas to accelerate it doesn't. Also my check engine light has been on so I went into auto zone and I got the codes.
P0303 - Cylinder 3 MisFire Detected
P0089 - Fuel Pressure Regulator 1 Performance
P0299 - Turbocharged/Supercharged Underboost
i have no frickej idea what it wrong with it and what I need to change on this car. I was told it could be something with the whole fuel system or something like that. But, currently I'm running out of options and I don't know what to do. Please help me?
Old Jul 28, 2017 | 10:51 AM
KingWulfgar's Avatar
Check the cam follower first. Failure there has been known to cause several of these codes. If that's good, P0303 could be something as simple as a bad coil pack. Swap it with another cyl and see if the problem moves. You can do the same with a spark plug (or just replace all 4). I would say the P0089 is likely the low pressure fuel pump (had this with mine).
P0299 - that one could be worse. Anything from the diverter valve (if you still have the old style) to a bad wastegate/turbo. Try to solve the other two first and work from there.
Old Aug 1, 2017 | 10:33 AM
rhodes991's Avatar
If you haven't changed the diverter valve I would start there. It is inexpensive and not to difficult to swap out. I got the P0299 when mine went. Do what King states and check/replace the cam follower. If that thing wears through it can cause major damage.
Sammy~D
Mar 7, 2013 08:59 PM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
TurboToughTT
May 14, 2008 02:19 PM
bdmurphy
Mar 13, 2005 09:56 PM
