Brake change at dealership?
Old Feb 9, 2012 | 02:55 PM
  #31
jagtoes's Avatar
Originally Posted by alonebb
what is the oem brand of the break pads?
If you want OEM call an Audi dealer parts dept. Just takes a few minutes and you'll get their prices. While there ask them how much to install.
Old Feb 10, 2012 | 12:27 PM
  #32
alonebb's Avatar
Originally Posted by Ericcg82
If you are looking for OE pads and rotors then check ECStuning, not sure if it is the absolute lowest price but I find them to have the best selelction. you might as well get the hardware if changing the rotors for the few $ is costs..
do you know the name of tool that push in the piston in place? as i watch in the tutorial in youtube, ppl have a specific tool to do so.
Old Feb 10, 2012 | 12:52 PM
  #33
Ericcg82's Avatar
I have this kit here, it will have what you need for your Audi and then some...
Audi B7 A4 Quattro 2.0T > Tools > Brake Tools > ES#9747 11 - Piece Brake Caliper Piston Tool Set - PBK-11PCS
Old Feb 10, 2012 | 01:36 PM
  #34
2wdBlazer's Avatar
I huad a cheap little socket attachment that had many sides and cube shaped. Different grooves on each side for different brakes. That turns the piston buy i had to use a clamp to compress the piston. It is a turning and compressing motion clockwise at the same time.
Old Feb 10, 2012 | 07:14 PM
  #35
jagtoes's Avatar
I believe you can rent a piston compressor kit from someplace like Autozone. I tried the cube attachment and it was a little difficult to both turn and compress the piston. Also I had to modify it to make it work. I finally used my buddies snap-on kit which made it a 5 minute job.
Old Feb 13, 2012 | 12:45 PM
  #36
alonebb's Avatar
i see, how can I identify if I did it right compressing the piston?
Old Feb 13, 2012 | 05:15 PM
  #37
jagtoes's Avatar
You need to turn the piston all the way in (clockwise) and bottom it out. If it is not all the way in you won't be able to install the new pads.
Old Feb 14, 2012 | 09:27 AM
  #38
Ericcg82's Avatar
you shouldn't have to force it, I've seen the cube things but FWIW and for how many brake jobs I will do it is worth the $40 buying the kit....How do you know if it is done right? Well if it is done wrong you are going to need a new caliper @ ~$400 from Audi and that is the only place you can get them from as far as I know...
Old Feb 14, 2012 | 10:07 AM
  #39
jagtoes's Avatar
You can get rebuilt calipers for $50-$60 each either fronts or rears. As for new fronts you can get ATE new calipers for around $280. Many aftermarket suppliers sell them. FYI
Old Feb 14, 2012 | 01:01 PM
  #40
alonebb's Avatar
Thank you~
should I order a set from Audi Parts - Vw Parts - Audi Parts Vw Parts Kit Company - Blauparts,
or Audi Parts | Audi Wholesale Parts | Audi Accessories | Cheap | Discount Audi Parts.
seem like audiwholesaleparts selling oem stuff~
jaymac
Feb 1, 2010 06:24 PM
biocpu
Apr 26, 2007 06:56 AM
AudiOso
Apr 23, 2007 11:45 AM
MyDreamCar
Feb 27, 2007 06:06 PM
joeytattoo
Sep 4, 2004 06:13 AM
