CEL after engine air filter replacement
Hoping to be pointed in the right direction here. I recently replaced my air filter with a Fram CA9409 filter. This is the first time I replaced an air filter on my own. A few days after replacement my check engine light went on. It kept turning off and on every few days for 2 weeks or so. Finally took to Midas and one of the guys said the filter cover wasn't installed properly so he fixed it. He said I probably have a bad air sensor if it comes back on. CEL stayed off for 2 days and then came back on and now it's on permanently. I recently got my safety instepection and the light was off after I got the car back (I assume CEL was reset during the insepction). Unfortunatly I don't know the actual fault code. Any ideas before I take to the mechanic? Car drives fine as far as I can tell.
Thanks
2007 A4 Turbo
Thanks
2007 A4 Turbo
This. You can't tell much without the code. It could be a myriad of things.
