Changed from C5W bulbs to LED bulbs - Number Plate Bulb error.
Old 06-03-2008, 05:32 PM
ryuujin's Avatar
Default Changed from C5W bulbs to LED bulbs - Number Plate Bulb error.
Hi
I recently installed some C5W LED bulbs in the number plate lights (rear, obviously). And I keep getting an error, because the car thinks that the bulbs are not working when they really are.
Is there any way I can fool the car into thinking that the light is really working? Or perhaps program it with VAG-COM so that it no longer checks the rear license plate bulbs?
Any suggestions.
Old 06-04-2008, 12:08 AM
cstarky15's Avatar
Default RE: Changed from C5W bulbs to LED bulbs - Number Plate Bulb error.
you have to add resistors! otherwise NO go.
Old 06-04-2008, 03:40 AM
ryuujin's Avatar
how do I add them? Where should I connect them?
Old 06-04-2008, 01:34 PM
harryd14's Avatar
ya i would like to know as well... is it hard to d as well?
Old 06-04-2008, 10:18 PM
dmfan016's Avatar
connect the resistor after the 1st LED in the circuit your running the LED's in
Old 06-05-2008, 11:54 AM
harryd14's Avatar
where can you buy those resistors and how much resisrtance?
Old 06-05-2008, 05:47 PM
dmfan016's Avatar
resistors can be found at radio shack, they are small and reletively easy to work with, as far as exactly what kind bring in the LED to radio shack or know the amp and wattage of the LEDs your using and they will set you up with the proper resistors
when you learn about how and why LED's are different then standard bulbs you'll understand why you need resistors because the current is different
i only know this because my roomate (i'm a college kid) made his own custom LED tailights and i helped him out with it....they look sick tho
Old 06-06-2008, 06:29 PM
harryd14's Avatar
o ok cool thanks man
AJ360
B8 Models
03-08-2015 07:04 PM
AJ360
02-13-2015 04:58 PM
AJ360
02-11-2015 11:01 AM
mosa
06-16-2012 11:19 AM
youmeill
03-07-2012 10:37 AM
Quick Reply: Changed from C5W bulbs to LED bulbs - Number Plate Bulb error.
