Engine Fault Code P2293
I'm getting the same code and have already replaced both pumps along with the cam and follower. I was wondering could it throw this code and limp mode bc the fuel pressure control module as well ? Also if it helps my fuel gauge is reading way off with levels in tank and the car will idle and run perfect, but still in limp mode. The only time it idles or sounds like it's mis firing bad is when I delete Codes
https://www.audizine.com/forum/showthread.php/805950-P2293?p=13364575
