Engine Management Light (Advise Needed)
Recently my engine began to idle really rough constantly fluctuating and causing the car to shake. This then brought on the Engine management light.
I changed the coil packs but still had the same problem.
I then changed the PCV which has seemed to fix the rough idling. I then disconnected the battery which turned out the engine management light and stayed off for two days but this morning it came back on although the idling is still fine?
My cars a 55 plate 1.8t A4
Any advise would be grateful
I got the codes cleared but the engine management light came back on after 2 days with the following codes:
16891/P0507
Idle Control System
17700/ P1292
Map Controlled engine cooling thermostat-F265 open circuit
17544/ P1136
Long term fuel train add.fuel tank1
Please help guys??
16891/P0507
Idle Control System
17700/ P1292
17544/ P1136
Please help guys??
