Loss power during mild acceleration with Smoke and jerking engine
Old Sep 6, 2017 | 01:37 AM
samnova's Avatar
Default Loss power during mild acceleration with Smoke and jerking engine
Hey guys, I have a A4 B7 2.0T 6speed manual @109K miles, completely stock. I drove from LA to the Bay area and stayed there over the summer. The car has some acceleration issue. I first noticed during the uphill road either on highway or regular road. if I step on the gas pedal to hit around 2200RPM to maintain the speed on uphill or mildly accelerate on hill, the exhaust burst smoke and I can smell from the open window (exhaust gas leak out from engine bay?). I can feel the engine stuttering/jerking with some clicking/ticking noise from under the hood.
Now I am back to LA and I found the car experiencing the same issue even on the flat LA freeway if I pull the car to pass 2200RPM. This could happen on any gear but mostly on high gears (4-6 gear). This did not happen every single time but I will say about 35% of the overall time. Also the car will burst smoke from 2200RPM to about 5500RPM (I did a test) if the smoke starts while I keep push the gas pedal without changing gear. However if I up/down shift and release then step on the gas pedal it may not happen again in the next gear.
Some other things I noticed and may link to the syndrome: 1. if I turn the A/C on, I can feel the power loss and the RPM drop faster when pressing clutch during gear change. 2. The car consumes much more oil than before: 1 qt for 500 miles!!
The valve cover gasket kit replaced @ 100K mi and same as the spark plugs. PCV recalled @90K mi
First thing I am guessing is the PCV since I can smell the smoke while I was driving on highway, but it’s only 20K old… second I want to check turbo, but how can I check since I did not loss the boost? Then I was to check the ignition coil as I heard it is a common issue and it may cause misfire… these are my top ideas. Those parts are expensive I don’t want to shoot blindly…
This is very weird and I am hoping it won’t blow the turbo or any internal components. I appreciate any possible ideas/help you all may be able to offer. Thanks!!!
Old Sep 7, 2017 | 10:41 AM
rhodes991's Avatar
Sure sounds like the turbo may be on it's last legs with the loss of oil and smoke. Might be time to have a trusted shop take a look at it. If it was the PCV I would think you would throw a code.
Old Sep 8, 2017 | 02:19 PM
KingWulfgar's Avatar
My vote goes to a cracked valve cover being the cause of your oil consumption/smoke issue. Very common.
Old Sep 8, 2017 | 09:06 PM
rhodes991's Avatar
I discounted this as they said the gasket was replaced at 100k. Would have thought the valve cover was fine.
Old Sep 11, 2017 | 10:08 AM
Easy to replace the gasket and not notice the cover itself is cracked--especially the internal passages. In fact, replacing the gasket can lead to cracking the VC (they're old and brittle now). Mine was stuck on good after 100k+ miles and it's only because I knew ahead of time to be careful that I didn't crack it trying to get it off.
Chriscz
Jul 6, 2016 07:45 AM
vikrambahogun
Dec 4, 2015 04:36 PM
virgiltu
Sep 15, 2014 10:28 PM
mzo0163
Dec 15, 2010 01:00 AM
doomwalrus
May 9, 2009 11:37 AM
