Low Oil Pressure
Just did an oil change on my 08 A4 2T and now am getting a low oil pressure light. I used a Mobil 1 filter and thought it looked a little different and believe this is the problem. Quick stupid question - can I change the filter w/o draining out the main oil - ? I'm not sure if the oil will continue to come out of the filter area since I always drain it first before removing the filter.
Ok I found out for myself - you can chnage the filter w/o much additional oil coming out, no problem. Also, the Mobil 1 filter has some kind of plastic plugs on both ends and these were an issue - filter did not fit correctly.
Finnie1967
Dec 5, 2012 02:45 AM
rustyleskiv
Apr 11, 2006 01:15 AM
