Low Oil Pressure
Old Jul 17, 2012 | 12:58 PM
ccmnova's Avatar
Default Low Oil Pressure
Just did an oil change on my 08 A4 2T and now am getting a low oil pressure light. I used a Mobil 1 filter and thought it looked a little different and believe this is the problem. Quick stupid question - can I change the filter w/o draining out the main oil - ? I'm not sure if the oil will continue to come out of the filter area since I always drain it first before removing the filter.
Old Jul 17, 2012 | 02:59 PM
rhodes991's Avatar
Not sure where the filter is located but if it is below the oil pan than yes it will still run out.
Old Jul 17, 2012 | 08:36 PM
ccmnova's Avatar
Ok I found out for myself - you can chnage the filter w/o much additional oil coming out, no problem. Also, the Mobil 1 filter has some kind of plastic plugs on both ends and these were an issue - filter did not fit correctly.
pdxrado
Jan 28, 2013 06:35 PM
Dallas09
Aug 30, 2011 05:57 PM
kerNol
Feb 25, 2009 09:53 PM
rustyleskiv
Apr 11, 2006 01:15 AM
