New A4
Wow, an inch and a half drop seems like a lot to me. I'll have to think on it. I really like these wheels, but I'm unsure of fit, sizing, and final results.
PS - Glad to have another active member around. The forum has been a bit dormant lately.
Yeah, I'm not sure I'm willing to pay what I imagine the price is. I'd get the gunmetal ones, so cleaning wouldn't be too much of an issue. My Akebono pads barely dust at all, so my wheels tend to stay pretty clean.
Here you go. Ross-Tech Store: VCDS VAGCOM/VCDS is the best tool for diagnosing issues and tweaking parameters. It's a bit pricey, but the amount of data you can get out of the car's computer seems to make it worth it. Back in the day, I used the Lite (free) version and a cheap knock off cable to reconfigure a few things (euro style headlights, key fob up/down, seat belt chime), but since then, my Windows laptop has died and become obsolete so I need to work on getting that set back up before I jump on the full VCDS/Ross-Tech cable setup.
Personally, I am torn between the Niche Forged Apex and the Rotiform APX, although those Crave Mach 7 look sharp too... The Niche Sport are very similar to the V810's, and these renderings are of a lowered B7 with 19's.
I saw the lite version of VCDS, does it program much of the ECM or DCM parameters or is it pretty limited? (ECM and DCM are bimmer engine control and digital control modules, I am not sure what the B7 call these). I would like to do the basics, diags, tweek lights and bells, I assume the lite version does not calibrate fuel/air, shift points, etc...
I just don't want to bottom out on all the speedbumps. I also don't want to change the ride comfort level TOO much. I'm ok with it being a bit more aggressive, but it's such a smooth car, I'd hate to break that.
I have a silver A4 and currently have the standard wheels:
I like the idea of a dark finish wheel to contrast the silver and think 18" might be enough for me. Not sure I want to go to 19". Tire price and wear get fairly ridiculous at that size. I'm also a bit unsure about the spare. I've always heard it's bad to drive on a mismatched (outer circumference) tire on AWD vehicles. I guess I'd have to make sure the outer circumference was the same and replace the tire on that one. I dunno. So many options and I'm not too much of a DIYer. I can do simple stuff, but anything that requires me being under the car is not my forte.
I have a PDF I printed out of an old Audizine forum post about VCDSLite. If you PM me your email address and can handle a 2MB file, I will send it to you. You're right. It allows you to change some basic things, but to do anything really advanced, you need the real cable (it has a security dongle built in so that only their cable works properly).
As for mismatched tire sizes, you won't have to worry about that if you keep the outer circumference the same, here is a link to show that the stock 17" size and the 19" size I am planning on going to will look like. Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit As you can see I am actually loosing 9mm of circumference and 1.35mm in ride height. So yes, the 19" will fit perfectly.
PM sent.
I like the first three and if I had to pick I would take the Mach 7 (and it wouldn't take any arm twisting). I like the first image next and the second image as last. They all looked pretty damn nice.
I saw the Mach 7's on a new Camaro today and they looked sharp.
I also have to replace my shocks at the same time (ouch).
Those were my favorites out of the ones you posted. How do you like those H&R (Sport?) springs? I keep going back and forth on H&R Sports vs. Eibach Pro Kit. I just can't decide. I like the extra lowering of the H&R, but am scared of a harsh ride and can't afford to do this twice.
I want to put Eibach's on the 650i but I can't comment on the difference just yet.
94b16coupe
Apr 7, 2009 08:12 PM
