rear window seal to convertable top broken. any advise?
Old Dec 16, 2012 | 11:30 AM
bkd2112's Avatar
Default rear window seal to convertable top broken. any advise?
Greetings,
i have a 2006 a4 convertable and the seal for the canvas top and rear window have seperated. im wondering if anyone has had this problem and if there is a good diy fix for this. any advice would be appreciated
Old Jan 10, 2014 | 11:55 AM
nikki11forever's Avatar
Default Did you find a fix
I have an 06 A4 as well and am having the same issue. Water is getting in and they want $1900.00 for a brand new top. I was hoping you found a solution or easy repair that you can share with me.
Thanks!
Old Apr 13, 2016 | 12:59 AM
rolex11's Avatar
Me three....
Looks like it is separating where it appears to be glued. In my opinion I think mine has done this due to cleaning the outside surface. Because you put downward pressure when doing this it slowly works its way apart. I have gotten into the habit of putting the top up/down half way and cleaning it when it is vertical to avoid this. Especially now that it is separating so much and any pressure seems to cause more separation.
Going to have a few top shops in the area give me some suggestions. Hoping it can be re-glued. Hate to have a new top installed, as mine is perfect other than this problem.
Attached Thumbnails rear window seal to convertable top broken. any advise?-img_1228.jpg
BennieboyUK
Aug 9, 2011 04:01 AM
virtualelvis
Jul 20, 2009 10:56 PM
96rsclipper
Mar 30, 2008 08:16 PM
shovin
Mar 14, 2007 07:03 PM
mslake
Mar 11, 2007 05:42 PM
