RPM Hang up
Old Mar 8, 2011 | 12:39 PM
DBAUDI08's Avatar
Default RPM Hang up
Has anyone had a problem with the RPM's hanging a little longer then they should be when switching gears.
2008 S-line A4 2.0T
Old Mar 8, 2011 | 04:30 PM
KingWulfgar's Avatar
What transmission do you have?
The FWD, automatic models come with a CVT which doesn't really "switch gears."
The quattro models include a typical automatic transmission and I've had no real issues with mine so far. It's not as zippy off the line as the 6-speed manual, but it's nice not having to shift all the time in the traffic we have around here.
Old Mar 8, 2011 | 06:07 PM
Audi Tek's Avatar
Tech Certified
9 times out of 10 its doing what its designed to do.
If you have a trans problem.... it will be not going anywhere, slipping, or banging gears.
Old Mar 9, 2011 | 09:03 AM
DBAUDI08's Avatar
I have a 6 speed manuel quattro with 25,000 miles on it. It seems after i let off the gas and press the clutch in is when the rpms hang for a little longer then expected or even rises about 500 rpms. If this makes any sense
Old Mar 9, 2011 | 01:05 PM
2wdBlazer's Avatar
Clutch could be slipping.
Old Mar 10, 2011 | 12:00 PM
DBAUDI08's Avatar
ended up being the clutch sensor!
Old Mar 11, 2011 | 01:48 AM
Mike-2ptzero's Avatar
A dual mass flywheel is always going to hang a bit before the rpms drop.
Dozanti
Sep 22, 2010 12:44 PM
hiwords
Jun 21, 2010 06:19 PM
joelsindc
Nov 16, 2007 04:49 PM
theguy1084
Mar 19, 2007 12:08 AM
Towlie
Dec 13, 2006 01:27 AM
